Where to plumb a return line on a Case 2390
JoeBob-IN
I need to run a return line from an orbital pump. Where is a good place to add one on a 2390? I thought about just dumping back into the fill port. I figured I could cut a piece of innertube rubber to make a seal and fasten it over the port with a hose clamp. I though I could fasten the return line solid to the tractor and stick the line through the rubber. Unless there is a good place to plumb back into.
Any chance you have a plug somewhere on the reservoir? My farmall had one that I removed and dumped my FL return into.
Good Luck,
Dave
You might want to ask on the Case forum.It might have to be returned to the endcap of the aux. valve stack for the pump to operate right.
