Hello I went and looked at a JD 2010 1965 model tractor it comes with a set of heavy duty adj.7'disk, row makers, 16" two bottem plow, grader blade, middle buster 5' brush cutter. The front tires are 75% and the rear tires are about 60%. Tractor has around 1000 hours on it, it was bought new by owner. Paint is a little faded, but still looks ok, The tractor has been setting in the barn for the last 6-7 years. The wife used it to cut the back field after husban got down and could not, said she ran it last Oct. 2009. I did not get to run it the battery was down. What do you think this would be worth, she is asking 6500.00 The tractor is a 1965 but was bought in 1969 new according to sells slip.
