Anonymous-0
I placed a new resistor on my b farmall that allows the current from a 12 volt battery to be reduced to a 6 volt coil. When using a test light the light is bright on the wire (posts) of the resisitor where the current comes in and is dimmer on the wire (posts) where the current goes out into the coil.
Question 1-Should the outcoming electrical current be dimmmer
Question 2-Are resistors poloarized or can they be hooked up either way.
ALSO
When I was trying to start the tractor I have apparently blown out the starter switch and the resistor was very hot.
ALSO
