Fuel system prime on jd 4430
Reid1650
How do you prime the fuel system on a jd 4430. Im an idiot and ran it out of fuel while goin down the road now its sitting in a neighborhood. Its got two block style filters and the manual pump you screw out and pump if you pump the manual pump and start itll start strong then sputter out. Im sure theres air in the filters but not sure how to get it out. Thanks guys im still livin and learnin. Worried sick right now as it sits
Gotta find the bleeders at the filter. Bleed them there and then crack an injector line until solid fuel flows. Atleast that's if it's an older model with all mechanical fuel system. Not sure where the bleeders are exactly as I'm not familiar with JD's, but find those and bleed them until you see no more air.
Donovan from Wisconsin
on your filter block, there's a air bleed, loosen then pump like the devil till you get raw fuel, tighten and pump tight again, start tractor
look at the filter top left of housing bleed plug open and pump the primer till you get fuel no bubbels close the bleeder now pump the the primer 8 or more pumps lock it down start it dont mess with thr inj lines
I guess cracking the injectors depends on the tractor. We've got a Massey 285 that won't start until a line is cracked, where our Oliver 1855 will start after the filters are bleed.
