OLD / LARRY
JR.Fyre
Good mornn : guys. I plowed a bunch snow yesterday
put out a new burn barrel and worked on the wd-45.
I am trying to figure out how to stop the end loader from creeping up or down, I thought I had prety well adjusted. But I guess not. I am all so
thinking about traiding it for one that power stearing.Will guys I have some stuff I need to get done, so Id better get at it,Now you guys stay out of trouble up here on YT OK, HAVE A GOOD ONE.
JR.FRYE
Does the tractor have the hydraulic decal on the right side of the battery box, or do you have the operator manual with info on how to set the pump and valve? In a wide range of the lift lever, there should be no action. Lifting should commence when the lever is almost near the top, and it should hold when slightly lowered. There are four screws to set.
