Re: Wisconsin LPG Motor to Gas
It only has a LPG carb on it now or was converted and still has gasoline carb on it too ? May need a gasoline carb, gas tank, and gas manifold if those were changed. Check for a parts catalog for it at Wisconsin Motors under engines and for carbs & other accessories there are more downloads under the accessory section.
Wisconsin & Continental Parts Catalogs
Some factory engines had special high-compression heads which are not in the on-line catalogs. This might be a problem if you are below 4000 ft. altitude with gasoline.
There is no difference in the distributor or manifolds.
If you have the high-compression heads, they are worth something, because they are no longer available.
