eric jones
New User
Hello All,
I am working on a JD 2155 that will only move when it is low reverse. The tractor has an 8 speed hi/lo trans with shuttle shift. I do not think that main clutch is out because it will work good in low (gears 1-4) reverse. but when i move the shuttle shift to forword the tractor tries to move but doesn't or it hardly moves. When i put the trans on the high side the tractor will not move in forward or reverse. First thing i checked was all the linkages in the shuttle shift and they seem to be tight and in good working condition. Second thing i checked was the fluid level in the trans and the was ok also. the hydraulics on the tractor (brakes, steering, and 3 point) seem to work very well also with no "chatter" What would i look for or do next to locate and fix my problem. Thank you very much.
