Anonymous-0
In the shop where I work, we have a 220 volt Baldor grinder and a 120 volt Baldor buffer. We needed to relocated these so I had to extend the conduit and wiring. The grinder (220) has two hot wires going into the switch and 1 white wire that is connected to a grounding screw in the back of the metal switch box. The buffer (120) had its own separate hot wire and then the same white wire from the grinder continues and goes to the buffer's junction box. The buffer's motor only has two wires - black and white. Everything worked fine before I relocated and everything works fine now but I am wondering if this is ok and safe?
