lower 250 belarus
If I recall, you take out 4 ? bolts and the bull gear housing rotates. And reinstall bolts in new position.. I hope that I am remembering right.
You are correct,but there are studs and you have to pry the housing out some then rotate down.If it won't come out enough to clear the studs,I believe you have to loosen the brake bands.Been a long time since I've done one.
