(reply to post at 20:24:10 01/21/10)
The other F factor is these:
First "ratings" have, can are, and will be "manipulated" by the advertisers. In other words, "they" lie.
This means that a 400W inverter "might be."
It means that XX amp hours is a "maybe."
BUT.....as others have said you have to allow for efficiency factors AND......
amp hour ratings of a battery are not "cast in stone." Google up "amp hours"----the traditional old way of figuring amphours was at the "20 hour rate."
This means that ANY amp hour rating is figured on this 20 hour fudge, and it ALSO means that as the current goes up---the math figures get more and more skewed---that is say, a 100 amphour battery when subjected to say, 20-30 amps is NOT a 100 amp hour battery, but must be DERATED at that high amperage draw.
SO what is the right answer?
It really comes down to.....
experience.
IF you have say, a trustworth RV dealer, etc, someone who is IN the everyday business of "knowing" and they say that this "model Y" inverter will deliver xxx reliably, and THEY have a good reputation, then maybe you can believe it.
If they ALSO say that you need ZZZ amount of "battery" REGARDLESS of what the battery "label" says then maybe you can believe that.
HERE is a sidedamstory fer ya. Years ago I installed E911 dispatch gear for "awhile."
We were at this newly remodeled dispatch, finishing up "stuff" when other contractors were doing stuff like "testing their UPS" The UPS in this joint had a battery bank about as big as a big coke machine. A telco guy and I were "back in the jail" (building had been remodeled numerous times) and we were in a small isolated telco closet.
WHEN THEY pulled the line power to test the UPS HERE is what we discovered:
Even though "important" stuff like the coffee pot was on the UPS,.......
There were no emergency lights outside of dispatch
the jail intercom system was NOT on the UPS
Neither were the electric door locks.
So there we were---in the dark--with my trusty mini--mag light
We finally found an analog outside phone line---no small deal in this digital world---and actually called dispatch from the telco closet.
GET US OUT OF HERE says we.
