Current Project Picture
2510Paul
I always really enjoy the pictures posted here so here is mine. This is a 1971 2520D I am working on. New brakes, axle seals, tires all around, radiator, seat, flashing lights on the fenders, light switch, dimmer switch, one new end rod on the steering rod, and many other small parts.
The bolts that go through the hub to hold the wedges between the hub and rim (8 per wheel) were rusted so tight that about half of them I had to cut off flush, heat cherry red from both sides, let cool for a day and then finally I was able to drive them out. As you can see the rims and hubs were sandblasted and painted.
The 3 pt draft arms were also rusted so tight I had to make a special pulling jig to pull them apart after much penetrating oil and heating cycles. The same was true of the tie rods in the front.
Enjoy the picture.
Paul
Looking good ! I sure am glad you were the one that had to buy those rear tires and not me !! Man tires are getting pricey.
Dustin IL
I cant wait to see the pics of it when it is finished. Always been fond of the 2520, beautiful tractor ya got there Paul
My plan is to fix whatever I can find to make it mechanically and electrically sound. This summer I will use it at a nieghboring farm to further check it out. I have an F145H 3-16 semi-mount that I will use with it and a JD 660 side rake. Someday I will paint it but not in the immediate future.
Paul
