old
- Location
- Camdenton Missouri
Ok since I'm home alone, wife in in Chicago for the boys graduation from boot camp which by the way he is no longer a recruit but a seaman or as some of you understand is an E-3.
Any how if I check the Resistance of this pump motor at the wires going to the pressure switch what should I get. Well is 100 foot so there's a little over 100 foot of wire and this is a 220v submersible pump. So what readings should I get across the 2 hot leads and then from hot to ground
Thanks
Thanks
