Re: My snow removal warrior - Pics - Share yours
Here's the same idea for Ford 8N
Looks just like mine, loader and all.you have 2 sets of weights,I have one. Sure can push a lot of snow.
Heres ours, 155hp 4wd. It will move alot of snow.
<a href="http://s702.photobucket.com/albums/ww25/F150Mustang/?action=view&current=Picture025.jpg" target="_blank">
Picture025.jpg" border="0" alt="Photobucket
</a>
So that's a 4000 8spd right? How does the reverse match up to the speed that the blower needs? Do you find yourself holding the clutch down alot to keep from bogging the blower? How wide is that blower? We have a couple 4000's, and I've been wondering about a blower for them
(quoted from post at 12:19:54 01/07/10) Heres ours, 155hp 4wd. It will move alot of snow.
Must take forever with just a blower. I can't imagine not having a plow.
NW bearcat were you asking me? Its a 5000 with an 8 speed. reverse low is a little fast but the blower can keep up. Then again I don't use it much, as the tractor will push lots faster than blowing.
His is a 5000. I've run a 6' blower on my 4600 for years. Works good in low reverse, can use high if you're just cleaning up a light snow or taking a narrow cut. Never had to ride the clutch or stop when in low. Usually run the blower with my 7600 now, so I can sit in a heated cab. :)
Its a duel chute, hyd swivel. Its kinda hard to explain how it works and i should get some pics of the back of it.
It 8 foot wide and had two V's that as you puch back it funnels it into the wheels that have paddles on them. I was told its a dodge truck axle that the wheel are bolted onto. It runs off 1000 rpm shaft. It will move 4 feet of snow in a 8 foot path but does take alot of HP! Its fairly well built, never had it plugged and can throw frozen clumps of dirt quite far.
Like i said, i need to get more pics of it as it is pretty neat to see the snow pouring out of it when ur clearing the yard. I have only seen two of these, ours and a neighbor 2 miles away bought one after seeing ours.
