Anonymous-0
O.K. I,ve got my ideas but need some second opinions on this one, actually two..
First one white field boss 4-150 1976 year
duals all the around. Inside tires about 80% out
side set fair to slick. Shows 2870 hrs been parked for 4 years in shed. Remotes with 3 point, 1000 rpm pto Looks better than average,all glass intact , Was told unit will
run and probably load its self but has weak main clutch. What is it worth where is.?
Second unit same shed been siting 5 years same year white 4-78 industrial tractor (Yellow Oliver) has industrial tires home made cab 4 wheel drive. Side mounted mo trim mower with bad
front pump..said the unit ran good when parked..
Location Middle Tn,, what is it worth?
