tractormiallis
My WD45 which I bought a year ago used to start fine and crank over easily. Then, after it sat for a couple months over the summer, it would not turn over. The battery was replaced after it would not charge.
The new battery, a commercial heavy duty with plenty of power did the same thing, acting dead and did not want to crank it.
I returned the battery for a replacement after it tested bad at the store. Now, the new one is doing the same thing. I cleaned all terminals, ground, starter connections. I am lost as to what the problem is, aside from being a bad starter. Should I hook it to my pickup to see if that will crank the starter? Your help is much welcomed. Thanks
