O/t 2005 Ford Escape transmission
Gene Davis (Ga.)
2005 Ford Escape with 3.0 V6 and it is time for the filter and fluid change. Does this transmission have a filter like the older rear wheel automatics did? If so how to change it and where is the filter located?
I just googled it and there are different opinions on whether it has a filter or not, as well as several different scenarios for changing it,from just draining it,to having to remove the trans to do it depending on how the car is optioned. Only common opinion is the trans is a very expensive weak link in the drivetrain on that vehicle
