Anonymous-0
I purchased a 1962 tractor recently. It has an original 12-volt system. The seller re-wired it to get it going after it sat for several years and obviously did not do it correctly. The tractor will start-up with a fully-charged battery, then show a buried-needle DISCHARGE on the Ammeter while running. If cables are left attached, the battery will be dead next time you attempt to start it. Seller also happened to mention that after he rewired it, both headlamps blew-out (complete with smoke) upon being hooked-up. Can somebody tell me what to look for as the most-likely mistake that was made by the seller?
Thank you.
Thank you.
