HammerByrd
New User
I have a JD450C Dozier. When warm and I clutch right track, clutch(not brake) will not reengage until I go from forward to reverse and back. I do not believe that it is a clutch issue because when it reengages and traction is good it will kill engine. Also at times when this occurs, if you clutch the left side and release, the dozier will just set still(you can tell that the engine is under some type of load when this occurs...). Shift from forward to reverse again and off you go.......Any ideals is appreciated....All hydraulic filters have been changed to no avail...
