James Howell
Just when you think that there"s no more room in the tractor shed, well you find <a href="http://www.youtube.com/watch?v=lCxV9jmtO7k">another old tractor</a>.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Rusty/?action=view¤t=003.jpg" target="_blank">
</a>
Located this <a href="http://www.youtube.com/watch?v=SH4xP5gw95Y">JD 51MT "Rusty"</a> just northwest of Greenville, TX.
It has an aftermarket 3pt hitch that appears to be designed especially for either an M or MT lift.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Rusty/?action=view¤t=005.jpg" target="_blank">
</a>
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Rusty/?action=view¤t=035.jpg" target="_blank">
</a>
Put 90wt oil in the upper and lower pedestal for the first time since it left Moline.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Rusty/?action=view¤t=012.jpg" target="_blank">
</a>
Naturally it started to leak.
Removed the front grill and used the air hose to "blow" dirt out of the radiator.
Adjusted the choke on the carburetor because it was sticking.
While checking out the Touch-O-Matic...
Other than two oil leaks, a radiator leak, a carburetor leak, and hydraulic leak, it is in <s>excellent</s> <s>exceptional</s> <s>exorcist</s> repairable condition.
Carburetor is off the K & K for a rebuild.
Radiator comes off and goes to the shop this weekend.
Will tighten hydraulic line behind the fan once the radiator is off.
Will replace both fan belts while radiator is off.
Will also replace the generator.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Rusty/?action=view¤t=009.jpg" target="_blank">
</a>
Just one more winter project to keep me busy and out of trouble.
