Stromberg Carbs aplication help
Joe Pro
Hello I have several single barrel stromberg carburetors, that I do not know what application that they are to be used for.
Where would I begin to look? I'm not even sure if they are for and agricultural application or not.
The number on the tag is 427003
Thanks for the help
Are they all the same? What is the manifold connection size and bolt hole center? I am looking for Stromberg 3/4" for Wisconsin AC-4
Phil
The bolt holes are 2 1/4 " OC and the manifold hole is about 1", could be 1 1/16 I don't have a mic in the house right now.
that sounds about the rite size for a MM power unit i've got...been looking for a carb to replace propane setup...does the carb have multiple idle mixture holes so carb can be reversed on manifold?
i gotta measure my intake again but i'm interested when you figure out what you want for one.
emails open
I too have some NOS Strombergs don"t know what they fit. These came from a old MM dealer is all I know so far. Will have to get some info on them.
The carbs that I have also came from and old Minneapolis Moline dealer as well. But I dont now of any MM aplication. But it is possible.
