Got our Case 585 running today after sitting for 2 years. The tank was flaking apart and clogging up the lines. I finally got the tank out several months ago and got it coated. Got it back in earlier this week, finished up hooking up the lines today after having troule locateing some fittings. Filled up with with fuel cracked the bleeder screws on the fuel filters, charged the battery while i cleaned up everything, 3rd crank she fired right up. Slowly pulled it out, had 2 flat tires, made it through one muddy mess to the compressor and got them filled up. I'm going to give it a good bath tomm to get all the junk off of it from sitting. Only thing i noticed is that the loader seems to be slow to lift up. How do you check the level of hydraulic fluid in this tractor? I'm sure it could use a fluid change.
