I bought a used front rim here for my MF135.The pictures of the rim looked good but when I received it the interior surface of the rim was extremely rust damaged.After spending an hour with a grinder/wire wheel I cleaned it up but do not think it will be able to hold air as the surface where the tire bead should seal is badly pitted.
Would painting the rim and using a inner tube work or should I just bite the bullet and buy a new rim.The old rim was bent badly by a skidsteer hate to replace good old steel with junk from India.
