Gary Spear
New User
Hello again,,,I was wondering how and if the cam gear/ignition gear are marked. My cam gear has a one punch mark in one place and a two punch marks in another,The ignition gear has only a two punch mark.How do I know when they are correctly aligned? When the no 1 piston is up and firing, the two marks on the cam gear are visible , not under the cover, that is and aimed somewhat at the ignition gear shaft, not perfectly centered,but in that direction,,And I have a spare gov./ignition gear assembly,,In the older one 1942 or so,,,the spring[in the center of the shaft and connected to the plunger] is longer than the 1947,will either work? The longer one is in better shape and I would like to use it...Woul d I need to use the weights from it also,,,Again any reply is very appreciated ,GB
