Anonymous-0
I have a green 5105. Darn thing only has about 300 hrs on it. It is getting hard to start. I have to turn the key off and on several times before it will fire.
I was told by a friend that has one that they have a problem with the solenoid in the injector pump going bad.
Great! I only use it to mow the fields at church. It's like a new tractor.
Can the solenoid be replaced...or do I have to replace the entire pump?
I would like to put a manual shut off on it...but was told the voltage comes from a module under the sheetmetal somewhere. Plus, if the solenoid enclosure is wet...then I would have a fuel leak.
I appreciate any and all help.
