Dave in GA
I've got some unrestored 1930s row crop tractors that run well. If I don't fire them up every weekend, some of them don't like to start because the carb needle valves stick up in the little plastic seats and won't let any fuel into the bowl. It's the same problem I've had with Tecumseh lawn mower engines and their similar needle/seat valves. I've tried adding some Marvel Mystery Oil to the gasoline and that helps some, but it gets old having to take a carb apart to get the tractor to start every other time. The carbs are clean inside and out, as they have been disassembled, cleaned with choke and carb cleaner, and reassembled. Are there any tricks to keeping these needle valves from sticking in the seats?
