gac
Hello all,
I have a W-4 and broke the end off the valve stem trying to put air in it. Tractor currently doesn't run and i don't want to get put a lot into it. Any suggestions on how I can seal it up so I can move it around without losing all the fluid?
Thanks,
Does the tube not have the typical rear tractor tire type threaded stem? Just buy a replacement.
The "core" can be replaced, which is what I broke off last week on one of mine. I got a used core at a tire shop, he had a coffee can of used ones, he gave me one.
I would get the fluid out of there before it destroys the rim.
Brian(MN)
My W-4 has replaceable REAR tube valve inserts, but the fronts area one piece stem. If you broke off the threaded section for a one piece, you'll need a new tube.
If it is the stem that screws in that has to be removed when filling tube with Ballist. Two at your local dealer will cost you less than $10 .
