Hi Bill,
I'm going off the top of my head and that can be really dangerous.
It's been too many years since someone picked my brain on the
subject, so what you get may be a little rusted.
The alternator/generator output is determined by the input.
Example: 12vdc at 100amp rating = 1200w@ 2000rpm is common
By applying a 80vdc input, then you'd expect a 15a output@2000rpm
80x15=1200w so your not exceeding the rated capability of the
alternator/generator.
To make the 80vdc input, you can series low ahr battery's.
From reading about current hy-brid vehicles using NIMH battery's,
there using a 80/20% rated state of charge to yield long battery life.
Me, I can't see why all battery recharging can't use the 80/20 scheme
on dry cell battery's to yield the same results.
If this is true, then one should be able too use a common made 90vdc regulator to regulate a 80vdc battery bank state of charge.
Depending on the 90vdc regulator spec's, that's going to put you in the 100vdc range on a full state of charge battery bank.
Using a common IC555 timer circuit, you can disconnect the generator input fields at 80% or 20% thus not over charging the battery's.
The IC555 timer circuit schematics should be easy to obtain over the internet. There very easy too roll/build your own.
A good source for home brew DC electronics is the ham bible, aka the ARRL Handbook, a great one source text reference.
T_Bone
