Video of me Making Hay.
Untitled Audio Video
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/YaARWzEHP88&hl=en&fs=1&color1=0xe1600f&color2=0xfebd01"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/YaARWzEHP88&hl=en&fs=1&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
That does bring up some memories. I guess the last hay Dad made was in the early 60's. We would pick the bales up out of the field, with the flat bed truck Those last few bales were sure hard to get up on the stack, we would hook hay hooks together to pull them up. stan
The baler. The center mount is really too low for the allis. It's probably right for the Ford tho...
Those angles cause the U-joints to work more than they would normally be expected to. If you were running the baler up to it's capacity you could expect a lot of heat in the joints before they go flying.
Rod
wheres the fenders on the ac? nice video thanks for sharing. Makes me want to get out there right now and get some hay down!
Looks like you did a good job on cutting, tedding, raking, and baling.
Sure did like your hay trailer; looks like you did a good job on rebuilding it.
Making videos from the tractor seat is a lot of fun.
Thanks for sharing your video with us.
(quoted from post at 17:53:31 09/17/09) wheres the fenders on the ac? nice video thanks for sharing. Makes me want to get out there right now and get some hay down!
Fender's are off because we had to replace Hydraulic lines for the lift arms. Which meant taking the Fenders, Fuel Tank, Seat, And platform out. Right now we are Currently Painting them.
(quoted from post at 20:24:49 09/17/09) Looks like you did a good job on cutting, tedding, raking, and baling.
Thanks, Not mm Favorite Wagon(Tongue is a bit too long), But sure beats 16ft. wagons! We have 3 18ft. Hay wagons.
I have quite a few more videos here- http://www.youtube.com/user/ACFarmer89
