OT: Well probblem with video link
Anonymous-0
This video starts with the well facet closed. After 50 seconds or around there you see the gage presser drop that is when the facet is opened and romaines open until well starts. Then facet is immediately closed.
The biggest problem is when you leave to facet open it only builds up to about 20psi and stays there never recovers.
Anyone have any ideas on whats wrong? Gage is new and pressure switch is new to. I lowered to cut of pressure to where it is tight now.
MMM.motionbox.com/videos/7a99dbb61612e7c1f5
Your video asks me to join to view. Nope. Try the video download on this sight below the add a reply box. Any well an pump near its last legs will not be able to keep up with an open valve. There are several common causes. Worn pump mechanism. Air leaks in the suction pipe. Scale in the jet venturi (if a jet pump), Plugged suction screen. Lowering ground water level. JimN
My experience with this is a bad pump, the pump just can't keep up.
What have you checked so far??
