JDtractormanalb
New User
Hi,
I have a John Deere 620 gas tractor.
Iis hunting both on idle and at other throttle settings, the only time it wont hunt is when i have the choke half way out.
I have disconnected the governer linkage at the carb and felt the movement from the governer when adjusting the cabi valve by hand, there is a bit of movment in the governer from when it want to open the throttle and wants to close it.
im guessing the governer weight pins are worn.
is there anything else i should check before i pull down the governer?
