Bruce Hopf
I have built a wood splitter, and I think that the I beam that I used was too light. The splitter I built is for the three point hitch of the tractor, and runs off the remotes of the tractor.
It is also Vertical. with the wedge that does the moving up and down, while the blocks of fire wood rest on the base of the splitter.
I have had the the I Beam twist, while I hit a tough block of fire wood, that is why I think that the I Beam is a little on the light side.
Any Idea what thickness of steel the I Beam should be, to be able to with stand that kind of pressure? Your input will be greatly appreciated. Thanks again. Bruce.
