ford 1300 tractor
brian bonner
New User
I am planning to install a front end loader on my ford 1300, where is the correct places to hook the pressure and return lines?
Read this:
www.hoyetractor.com/loaderinstall
BUT, I would never do it that way. I plumbed it where the lines enter the pump housing. That way you do not have to cut any lines...just in case you want to take the thing off on day.
There should be a block . That you can buy from New Holland that does that for you some come with it and on some tractors it is a dealer installed add-on. mine 1715 came with one installed.
(quoted from post at 06:39:24 06/19/09) I am planning to install a front end loader on my ford 1300, where is the correct places to hook the pressure and return lines?
:D :D my 1300 has an adapter block that bolts to the housing near the r brake drum
