Mathias NY
I have been having trouble with the clutch on my Allis B. It is adjusted so that the pedal will open the pressure plate as far as it will travel and both the pressure plate and the flywheel are free of rust.
However when the tractor is running, the clutch will not release enought to allow me to put the tractor in gear. I need to idle the engine down almost to a stall, then shove it into gear. I can't imagine this is normal. The throw-out bearing is questionable. Would this cause my problem?
