Ford 9n and Massey 230
Myra
New User
I need the height,length, width, and weight of these two tractors so I can transport them. They are not were I can measure them.
Would appreciate your help.
Thanks
Sorry Myra, but that is rather difficult to do without measurement of the width and knowing the tire size and whether there is liquid ballast in the tires and additional wheel weights.. The width can vary as the wheels can be adjusted for various widths..So width and weight can vary.........external_link would provide you with the factory specs on both tractors... The 9N will be around 115 inches from front to drawbar, and """""""normal"""""""" width (wheel tread) adjustment will give you a total width of about 65 inches.... It would weigh about 2400 pounds without ballast in the tires..... now, if there is a loader on the tractor, that is a whole different story.... and, grille guards were a very popular accessory that were fitted to the front of the tractor...
I think you'll find most of what you're looking for at external_link. Most of the dims/weights are listed for each tractor.
If the tires on the 9N do have ballast in them, you can estimate a weight of 3000 to 3200 pounds for the tractor.. I didn't mention accessories like stabilizer and sway bars, drivers seat variations, running boards, extra lites and samll addons that would vary the weight also... but 3000 to 3200 would be close for a "typical" 9N with ballasted tires......
