well i got the little pup trailer here, a long day, wasnt easy, it looked scary kingpin to landing gear wise, but after i removed my mud flaps, i eased back under it with the tractor , just when i knew it wouldnt go i got clunk! as the fifth wheel jaws closed,got it hooked, but you know theres always a But, this one was in the form of the landing gear having 12 inch in diameter steel pads on the end of the legs which were now 2 inches from the rear tires on the truck, i cant turn now at all, after over a hour trying to unscrew the pads, [ former carolina freight lines trailer] i got the fire wrench and removed them , no way to unbolt the gear, it was mostly welded on what bolts there were were very coroded, after bulding a set of wires so i had turn and brake lites from scratch, airing up the tires, which were suprisingly good, and putting gear lube in the dry axle hubs i hit the road, all the way back no trouble
