Follow up question to D17 12 volt
Our Phone System is Down!
Please use the Contact us Form
We are working to resolve the issue ASAP! Thanks for your patience!
Bevan
How do I tell if its a 12 volt or a 6 volt generator on a tractor? Assuming the lights are not marked.
I think also on Delcos the black tags were 6 volt and the reds 12 volt, can anyone confirm that????????
Also if one uses an ohmmeter to measure the combined field resistances (sum of each side) I think the 6 volt would be around 3 ohms while the 12 volt would be more like 6, can anyone confirm that???
I think the 6 volters have smaller commutator segments on the armature
John T
Good indicators (all) but between repaint, and unknown meter accuracy at small resistances, every option for an ID your friend, JimN
If the generator is charging a battery count the cells on the battery. Six on a 12 volt & 3 on a 6v bat.
If you have an auto electrical shop near you , take it in and run it on a test bench. The operator should be able to tell.
John T is right about the colors. Red = 12V. Black = 6V. The 6V generators are the same diameter the whole length of it. A 12V generator is smaller in diameter at the brush end.
P.S. All D series were 12V from the factory...
