I need some help. This truck is running a little warm from time to time, especially when pulling a hill. I have went through the cooling system a few times.
I have moved on to check the ignition timing, the manual says to check the sticker under the hood, the sticker under the hood says the timing is not adjustable and is computer controlled. This is not true since it has the same basic distributor running off of a cam shaft with a rotor and distributor cap.
Anyone know what the timing should be set on at idle for this truck. After cleaning up the makings on the balancer it seams to be 25 degrees BTDC, I did not think this was right, set it back to 10 degrees BTDC and lost all sorts of power. This was with the truck warm and at idle speed.
Thanks for any help.
