super M liftall
ohiojim
while looking for parts on the case IH website noticed a kit that boosts pump pressure from 500 to 800 psi, it is a discontinued item, anyone know where to get one or know how to boost pressure ?????
the very early h and m"s had the lower pressure belly pumps. the later, prolly 1946 and newer ran the higher pressure pumps. if i remember, the kit required some machining to tighten up the tolerances in the pump to get a little more pressure. i doubt if the kit is still available. it would be a lot cheaper to just get a later used pump. if you have a super m, it has the higher pump
