Absent Minded Farmer
- Location
- Gehl Country, Wis.
Well, this is a new one on me. With the engine off & the headlights on, the ammeter reads that it is charging. I do know the tractor charges nothing, so far, running or otherwise. Battery is ok. I can charge it overnight & get a good many starts from it after that. It's running a pretty new alt & the previous owner changed out the points. Inside what I thought was the box for the new points was another brand new points set (a sign maybe?). It has an odd buzz comming from the distributor as well. The engine cuts out, at 3/4+ throttle, every once & a while. Shuts down - dead. Crank & crank & crank & then it put-puts to life like a hit-n-miss. It could act up a half hour later; it could act up a few days later. No set pattern. Any ideas? Thanks - Mike
Sorry about the pic, btw, had to use my phone.
