Sediment bowl w/ in tank screen?
Mitch D
Wondering if anybody knows where I would be able to find a sediment bowl with a screen up in the tank on the inlet. Tank was clean but now have a bunch of those asian beetles in it and cannot get them flushed out. It is on my JD A. Thanks for any advice.
Make it yourself. Find a piece of fuel line that will fit into the inlet of your sediment bowl. Drill out the inlet a smidge if needed. Cut the fuel line off so that maybe a 1/4" is protruding above the inlet, and then make a cylinder out of a piece of fine mesh brass or stainless steel screen. The cylinder can be anywhere from a about 1" in length up to maybe 2"? Use JB Weld to affix the fuel line into the inlet, and then a little more JB Weld to affix the screen cylinder to the fuel line.
do a search for "sediment bowl assembly" in google and turn your pictures on and you'll find 3 or 4 places on the first page alone. Power of the internet.
Ford tractors use them, also 6620 JD combine, they have a real nice one with tall screen, should be several used ones of those out there, good luck
Thanks guys I'll see what I can find tommorrow.
I would of thought they would float but they kept geting sucked up and cut off the fuel when we were out on a tractor ride.
