I'm spraying my corn and beans but I think the application rate is maybe a little light.
I was taught 5mph, 30psi equals 10gal/acre, now go dump in the chemical and go. Easy.
Except I misplaced my monitor book so I know my speedometer isnt set right. So I just did timed runs with a stopwatch and determined for 5mph I want to the speedo to read 5.7 or 5.8, but that is about 2100RPM in 2nd gear and for some reason my pump has only been achieving 23-28psi in that range. 1st gear doesn't get to 5mph, 2nd has too low an engine speed to get the pump to pump enough pressure.
I bought a new belt because I thought if it was running closer to the outside on the crankshaft pulley that would make the pump pulley spin faster for more volume/pressure.
So--if I can't make the 5/30 formula work, how do I adjust for proper rate? I have a 4 speed manual transmission in my spray coupe, a pressure-adjust switch, 8003VS TeeJet nozzles. I tested the nozzles and found that in the 30 seconds it takes me to go 220 feet (5mph), each of my 36 nozzles is putting out 17-19 (18 average) fluid ounces.
So I'm estimating, I'm putting on 16.67gallons of water / acre, and that out of my 200gallon tank comes to about 12 acres.
Is there a nozzle chart somehwer so I can adjust my speed and pressure to get my exact rate? Thanks!
