Heinar Johnson
New User
I have a JD 4010 diesel with a forward PTO shaft. I have tranny/hydraulic fluid leaking out of the middle of the PTO shaft from a threaded hole in the shaft.
Does anyone know if there is supposed to be a set threaded set type plug or a bolt that is suppose to be screwed into this hole?
I put a new PTO seal in but the fluid is still coming out directly through the PTO shaft.
