John Deere 3010
kwmcderm
Bought a 61 model 3010 gas tractor the other day with the knowledge that the lift was not working. It was not showing any hydraulic fluid on the stick. Added about 4 gallons of fluid to the tank with the hopes it would start working. No luck. The power steering and brakes work and did when i bought it. As I understand the same pump operates the steering, brakes and lift. Any suggestions? Thanks for any help...
I've seen more than on "new generation" tractor with a rusted control cable between the dash and the control valve, including my own 4020.
Look under the right seat cover for the control cable moving the shaft on the three point control box.
Gerald J.
