Wheel Weights
Anonymous-0
I have a 37 John Deere D with a set of D2628R wheel weights on the rear. I want to stack another set of weights on the D2628R. I was told these were used as the starter weights. Can anyone tell me the correct F&H weight to use to form the stack. I have a set of W162 weights that are not F&H and the bolt pattern matches up but the inner part of theses weights are to deep so they will not lock together. The D2628R weights have a fairly flat mounting surface.
They're more than starter weights. You can stack them, just rotate a little until mounting holes line up. Use 5/8 X 5" square head bolts. If you don't want to take off the weights you have on now use hex head bolts and square nuts.
