I have an old WWII army Jeep.
I was going to put new oil seal in with engine in. Looked up to see all cylinders and #4 has been scored by wrist pin. Question was had it been scored before and someone put together that way or is the pin loose and causing the damage now. I took head off and piston and rod out and wrist pin is loose now. Probably won't put over 1,000 miles a year on it. Should I sleeve it or just tighten the wrist pin and go with it that way? I really hate to take it all apart to sleeve without complete rebuilding it. The engine is in good shape and doesn't need rebuilding. Other than blow by on that cylinder I don't see what it will hurt to run it as is.
