how light weight
phil lowe
looking at this loader ,looks very light weight ,,which isn.t bad, cause I've been told my 3000 has light front end ,but would this loader be better then my back scoop and not so heavy to screw up my frot end?
Untitled URL Link
definitely not an expert on front end loaders but it may help if we knew how much the loader will be used and for what. also the price would figure in too, may be a good buy. i can think of alot of things i could do even with a light weight loader
larry
I don't know how big the 3000 is, but my loader is heavier than this one and I do (did, it's dismounted now) fine. Steering over rough ground with a round or big square bale hanging off it is a different story.
My little tractor is 5ft widex 10ft long and weighs about 3000 lbs with 26hp.
Dave
thanks guys yup she's seen better days and been abused ,$300 bucks and a two furrow plow and spring tooth harrow for another hundred,,nice plow ,harrows not too bad..the hydraulic valve is probably worth least half that price.Loader needs work, lines are garbage and I did see the little "additions" to the metal,that'll fit right in with the rest of my gear I guess:)
oh the bucket is really small as well.that will limit how much I lift anyway.not sure what the plans are ,but hope to put my snow blade on it,and move some rocks n dirt around.
