I have an early model JD 3020 that the PTO quit working on. I could not get it to work even with unhooking the linkage and manually engaging the PTO so I do not think it is the linkage from the shift lever. Is there something inside I can't see that may have worked loose? If it is the PTO clutch I was wondering how big a job it would be to replace myself. I know the tractor will need to be split to do but after that is there any major work that requires specialty tools or work that could not be done by someone with average mechanical skills? Also, can anyone give me a ballpark cost for replacing the PTO clutch if that is the problem. This is a syncro-range transmission. Thanks to anyone who responds.
