tree masher
New User
This message is a reply to an archived post by Gene Bender on July 09, 2008 at 01:43:37.
The original subject was "Re: Oil in radiator".
I'm looking for info on using oil for coolant for short term use. I have an older backhoe I only use occasionally for minor jobs that has a cylinder sleeve o-ring leaking coolant into the crankcase oil as soon as I shut it off. As long as it is running it doesn't leak but turn it off, wait 5 minutes and there is antifreeze in the oil. It is a pain to drain both the oil and the coolant to use it for 10 minutes and it isn't worth the expense of a full rebuild.
