transmission slips in high gear
steveT
New User
I have a Case-IH 255 4x4 28 hp tractor. The transmission slips in the higher ranges. I had a guy look into it and the clutch, pressure plate are fine. Does anyone know what is wrong. No noise at all it slips like a worn out clutch. Please respond
Unless you have some other drive sytem I would bet on the clutch try adjusting it to see if that helps. You should have 1/2 to 1 in. of free play if its a foot peddle type. Hand type you adjust it up till it doesn't slip.
Walt
