jump start positive ground
BMAN
Can a tractor with 12 volt negative ground jump start a tractor with 12 volt positive ground?
To be more specific jump BATTERY (+) to battery(+) and BATTERY (-) to battery (-), and DON'T let the machines' metal frames touch.
Yes.
People get confused with a pos ground and a neg ground system.
But when jumping any vehicle no matter what the ground is you always hook two batteries to jump positive to positive and negative to negative.
If you would hook pos to neg and neg to pos you will be creating 24 volts (if both batts are 12v) and burn up both vehicles.
